I purchased a small stand mounted spray booth which I plan on using for some powder coating. As the booth was used it was in need of a refurbished to prevent any contamination issues as it was previously used for coating but not well kept. The booth is made from galvanised steel with the stand and outside of the booth being brush painted (visible surfaces) which wasn't the best as no prep was evident before painting. The inside of the booth was contaminated with an unknown powder from what was being coated which took some serious sanding to remove, so basically the floor of the booth is back to bare untreated steel, the paint on the outer of to the booth I sanded back to bare untreated steel. I bought some rattle can aldi metal paint - gloss white for the inside of the booth and Red for the outer. As I have removed the galvanised zinc from the steel is it advisable to use a primer or do I just spray the metal paint straight onto the prepped steel?
Many thanks
mike
Many thanks
mike
