ouchmyfinger
Sorry lads, but every time i think i got the primer/paint process down in me head, i read a thread which changes things. So please bear with me. Ok.
Assume ive stripped my BGT back to the metal, washed, cleaned and dried it.
1. I need to get a coat of primer on fairly soon so it does,nt flash rust.
2. i prime with either etch or epoxy, this seems to be down to preference.
3. i notice some damaged panels and corrosion.
4. Weld repair as required grind finish & prime, (areosol will suffice.)
5 Repair dents damage etc.
6. Prep, fill, stop, & block finish all repaiirs.
7. Now prime with high build primer 2 poss 3 coats.
8. Apply mist guide coat.
9. Block sand final prep for base coats etc.
10. Thoroughly check for any small imperfections and rectify if any.
Right lads have i missed or messed anything.
Paul
Paul
other than that looks like you got all the bases covered
