Hi,
Thought I'd share some pics of my first TIG welded project! I was determined to do this with my new TIG welder! lol....It was a bit of a long journey as everything had to be spotless, but I got there in the end even if a few of the welds have a little bit of contamination!.
First, me cutting the 50x50x25mm box section.
All cut and ready to clean.
My first TIG weld! Scary stuff, but didnt turn out so bad!
Finished!
I decided to stick weld 4 pieces of box section to the underside of the 10mm sheet and then drill some 10mm holes through the frame and the piecs on the sheet. Then I put some 10M bolts through the two pieces and bolted firmly on, just in case I need to take the top off at any point
Overall quite pleased!
Cheers,
Paul.
Finished!
Cheers,
Paul.
