whensparksfly
- ireland
is the Protools tube bender 105 any good what are they like to use and whats the bends like for 2.5mm 45mm cds or t45
Thats the only problem,i did see that bender where would i find the dies is what im thinking.thanks for all the replys
If you fit an attachment to it, (mine came with it) though i'm sure you could make something to work, it'll do 180 degrees with any of the formers,Does it take a 180 Die if you can find one ?
I've not done a lot of 1.5mm stainless tube but when i have its come out well without kinking,I have a jd32 at the moment with a 1-1/4 die which I use for 1.5mm 304 tube.
Have you ever tried this gauge in yours Chevy ?
I will have the need to bend larger diameter and heavier gauges also so something like this would do the job.
Depends if he knows its worth?Yeah will keep an eye on it,wonder what reserve it got.
Keep an eye on ebay,gumtree etc,i won the hilmor rh3 do ay of you know where to buy extra dies
