Bought this Ingersoll Rand compressor locally last week from an auction.
I got it fairly cheap as it wouldn't start up unless the tank was empty. I knew what the problem was - the wrong motor was fitted. It was a 2.2kw but it was a psc 2750rpm motor & hadn't the torque to start under load. It was also very badly fitted.
Why didn't they use the existing motor mounting slots & adjust the pulley position on the shaft to suit?
First thing I checked was the mains cable - found this as a fuse.
Yes, that's a very rusty hex screwdriver bit, making very poor contact with the broken fuse holder in the plug. The whole lead was replaced with some 2.5mm & a 16A plug plus I fixed some damaged wiring in the pressure switch.
But even with the wiring repairs it still wouldn't start. To check the pump was working I increased the capacitor size from the standard 45uf to 60uf. I have now got it working though only temporarily, a large step up in capacitor size is not good for the motor windings.
My decision now is to fit another 2750 rpm motor with capacitor start/capacitor run for better starting torque or fit a 1400 rpm 4 pole motor which should be better again though more expensive?
The good news is that the pump is working well & it is able to keep up with the die grinder. It fills up the 200l tank in 5 mins from empty. The bad news is that it's not the original IR pump, it looks like one of the generic pumps sold by machine mart, clarke & ebay.
Now to the main reasons for my post. This is an appeal to anyone who has a belt drive 3hp compressor, especially clarke ones that have the same pump. I would like to know what speed your motor is & what the approximate pulley sizes are.
This is so I can work out what speed the pump should run at. I have contacted the sellers on ebay & I'm getting anything from 1200 to 2800 rpm for pump speed! At the minute it is running at 930rpm & according to IR a cast iron pump should run at 1000rpm, but it's not an IR pump!
I am still undecided on a 1400 or 2800rpm motor, so it would be interesting to know what's commonly used. I can adjust the pulley sizes to suit either speed.
Thanks for your help.
