Hiya!
I`ve been given a large old single-phase air-cooled welder.....made by "Quasi-Arc"; it`s labeled as "ACP200" and might be a child of the `60`s.
Has 2 tap-changers giving range from 20-200 Amps. and is rated:
Primary: 190/480 V. 50Hz.
Secondary: 60/90 V. (No Load)
It was delivered with 40 (yes 40!) metres (each) of 'hot' and 'cold' cables!
I have a tractor-mounted log splitter project in the 'offing' and would like to use this set for welding the 'heavy gauge' components.
Given the plated primary voltage is 190: would it be ok to use it on my workshop`s 240 V.?....The set already had a 32A. 'bluey' on it, but `wanted to check with the experts here, before using it.
Thanks and with kind regards,
Deb.
Deb.
