Not often, always. Simple maths. Same flow from the pump, spread over smaller area= less mechanical advantage and quicker action. You can calculate it if you really want to!But is often faster at reduced power. (I think)
Well I wasn't going to mention balanced rams!Depends on the type of ram as well. A double ended will be the equal.
Does a hydraulic ram have the same power in both directions, or does the rod effect the power on that side.![]()
