Hi there. I have a Scion oxygen regulator, designed to be screwed into the top of an air tank. I'd like to re-use it as the "consumer end" of a compressed air delivery system I'm setting up in my workshop. Hence, rather than screwing the regulator into an air tank, I'd like to attach air delivery tubing onto the "air tank" end of the regulator, the air supply coming from a compressor elsewhere in the workshop.
Does anyone know if it is possible to get hold of any free-standing adapters that look like the connector on the top of an air tank?
Alternatively, I could connect the incoming air supply to the 3/8" BSP connector on the side of the regulator. However then I'd still need to be able to close-off the "air tank" end of the regulator, so the same question applies. FYI, I have tried to unscrew the metal pipe that forms the "air tank" side of the regulator from the cylindrical regulator body but it simply will not budge.
