This is what i've been looking at, the 45 degree ones as supposedly they are better with lower power.I have a Walter 45 degree 63mm face mill, takes SN__1204 style inserts i think. Leaves a lovely finish on steel and aluminium... I think around 1900rpm IIRC.
I also have a 90 degree 50mm facemill, it's a sandvik R390, this takes proprietary sandvik r390 inserts of which there was a whole load of available on ebay at the time. I have another couple of big end mills that take the same inserts.
Personally I'd just buy a mill body from cutwel and get some yg1/korloy inserts, generally they work great when you wind the surface speed up to reccomended speed.
I do have APKT for an indexable end mill, however they do seem to need a fair bit of power even on a three insert endmillIf you want well-priced inserts, APKT are about the most common, and hence most economic. In effect, they are the CCMT or GT2/3 of the milling world.
The problem is the 90° angle, it has to require more power.Cutwel/Korloy seem to suggest the positive rake of the AP inserts is useful in reducing power requirements.
See:
Alpha Mill 90 Degree Plunge Mill for APMT Inserts - AMS-MH (Korloy)
The Korloy AMS-MH series Alpha Mill is a 90 degree plunge mill which takes APMT inserts and is ideal for plunge milling on lightweight machines or difficult to cut materials. Diameters range from 14-32mm. The Alpha Mill offers the smoothest cutting action and the widest material application...www.cutwel.co.uk
The download on that page might find the best grade and geometry for cast iron.
See also 'double positive' discussion here:
Rake angles make or break facemilling
When it comes to cutting angles, the rake can make or break your facemilling process. Rake angles impact key parameters, such as chip flow, metal removal rate and tool life. So rake angles need to be chosen with an eye to the requirements of each application.www.ctemag.com
Just an observation: at 63mm size, the facemills tend to use 6 inserts, whereas at 50mm they use 5 inserts. And inserts come in packs of 10...
Another small thing to consider is that most of the facemills aimed at the home workshop level market, where machines are almost by definition low powered, use the AK inserts (see ArcEuro's offerings, Chronos/Glanze).
We've got some at work which take an octagonal insert, you get 4-8 edges depending how bad you chip it. They last ages even with less than ideal feeds and speeds in a manual mill. I'll check the manufacturer tomorrow.You also only get two edges on my ones which are korloy Alpha mill.
I read an interesting white-paper about this a little while ago from one of the machine manufacturers.Button tools are great for high productivity but don’t give the quality of finish you can get with many other insert geometries.
I am a big fan of round insert tooling
Bit spenny i agree.This is what i've been looking at, the 45 degree ones as supposedly they are better with lower power.
The korloy inserts would be what they call RM8, they're about £13 an insert so probably give those a miss.
The Spindle Power to Material Removal Rate relationship of round inserts varies non-linearly with DOC.I wonder if this might not be a little peripheral to Brad's primary requirement of wanting something that is suitable for a lower power machine.
He states the machine horsepower in the initial post and has mentioned power limitations three times already above.
