Hello
Once I sort out my drain off (another thread) I want to get my fixed lines installed and plumb my in-line filters in. Problem is that I need some advice as to best setup for my needs.
I plan to run the compressor (3hp 200ltr) on the other side of my brick garage (sheltered), so know that I need some flexible pipe to go through brick wall.
I have a paint-shop filter with twin outlets,
A Norgren water trap
and a norgren oiler all to plumb in.
I want to run air tools and also to spray paint.
Using 15mm copper pipe with drop down drains and riser where ncessary
Can anyone suggest the best way/order to plum these items in?
I'm thinking:
1st) water trap (max 150 psi)
2nd) Paint shop filter/regulator -1 outlet for paint gun & other outlet for air tools. Then;
3rd) Plumb oiler (max 150 psi) to other outlet of paint shop filter/reg.
Suggestions very welcome and thanks to those who do
Cheers
I'm thinking:
Cheers
