I have a compressor in the shed behind my garage the compressor came with a regulator on its outlet and then a tap. I have piped from there into the garage where I have 2 outlets one at the front on the pillar between the doors and one at the back over the bench.
The one at the front has a regulator on it and I always use that one for spraying. The one at the back has no regulator and I tend to use it for the die grinder etc.
The regulator on the compressor outlet has failed and is leaking air.
It seems to me that it is not doing a useful job and that I should just remove it from the system and not replace it.
Does anyone disagree?
