Kram
- Sussex
Ive been ignoring my exhaust about a year and now a small hole has spread into a crack. Id like some advice, the best way to weld it up, before it falls off
The hole was caused by me falling off on ice, it bent the exhaust and ripped an internal weld. Also becuase its slighty bent, refitting was not easy.
Will stainless care that crack has been exposed to exhaust gasses? I'm aware carbon makes stainless brittle, should I grind the damage out and patch it with sheet?
I can get a better pic tomorrow. This is the other side, when it was much cleaner.. The hole is on the left side of the bike, next to the mounting bracket (left of pic). Crack spreads round the diameter parallel with the weld (right of the bracket)
The hole was caused by me falling off on ice, it bent the exhaust and ripped an internal weld. Also becuase its slighty bent, refitting was not easy.Will stainless care that crack has been exposed to exhaust gasses? I'm aware carbon makes stainless brittle, should I grind the damage out and patch it with sheet?
Crack is between the sump and the bracket, not that accessible. It has been removed this year so studs are all free and covered in copper paste.
