Fazerruss
Good evening all, I'm on with another project which requires the motor direction reversing. This is a cheap designed for the job motor without the start and run windings connections in the terminal box so I've stripped it down to get to the windings connections. Before I go any further is there an easy way to do this. I can't make out any differing wire size to indicate separate run and start windings and there is no centrifugal switch on either of the flanges. There is an externally mounted capacitor.
So what kind of motor is this and is there an easy way to reverse it? Would changing the capacitor polarity have an effect or kill it? I only need to permanently change direction so no need have it switchable.
It's off a Rexon bandsaw that I'm modifying so will be cheap Chinese.
Thanks
![20180409_205620.jpg 20180409_205620.jpg](https://www.mig-welding.co.uk/forum/data/attachments/134/134361-0e9dae9419308783806859df4ee91fe1.jpg)
Thanks
![20180409_205633.jpg 20180409_205633.jpg](https://www.mig-welding.co.uk/forum/data/attachments/134/134360-f8456c85ef76d08f0b3a69289df134dc.jpg)
