Badger1bear
If your not on fire, then your too far away
- kent
Hi guys, hope one of you can help me. I have started changing cutting edges on loading shovels from time to time at work. I use a 1" us pro impact gun which is fed from a 90 litre mains compressor, you might get one nut undone before the compressor is panting on the floor ( I inherited this inadequate setup from the previous fitter)
it can take up to 30 minutes to do this simple job. My question is, would an atlas copco road compressor be ok to use ? Could I run the gun direct from the air outlet on the compressor or would I need air reducers on it ?
Thanks for any advice :-)
