While doing my car resto project, i get very little time to work on the car.
Where I had made my own patch repairs with new steel, in my wisdom I could see surface rust appering, so I brushed on rust convertor the the new steel after welding thinking that it was a good base/preventive rust measure.
You can image my shock when I came weld on top new steel. I thought I better hit it with a wire wheel on the drill to get to the shiney metal.
The rust convertor That I put on came off like a skin that would easily peel off
I take it that rust convertors are no good on new steel.
Should I use somthing like por/ epoxy mastic straight on the steel then??
