I was wondering if anyone has used a sealey SB993 portable sandblasting pot (tried to post a link but didn't work) and if are any good for small jobs?
Also, I have a few bags of fine sand, can I use it for blasting?
That device is an expensive way of buying a bucket. Really a pressure pot is best but if you must use a syphon gun get one from Machine Mart for £15.00 and buy a bucket from a hardware store.
I've just bought a professional gun with a tungsten carbide nozzle from Anglo-Scott abrasives for about £50, first impressions very favourable.
That's the one. The nozzles don't last very long though and on mine the trigger valve stuck and one of the grubscrews cross-threaded the first time I changed the nozzle.
As a matter of interest is it paint or powder coating you want to shift? That gun won't touch powder coating and may struggle with some modern paint finishes.
You'll really be struggling with a 1.5hp compressor, the one advantage of a syphon gun is that you can give short sharp blasts, but those guns use a lot of air. Could you borrow anothe compressor and use two together?
If I were you I'd take a punt on the Clarke gun and if it doesn't work you've at least had a new experience!
The Clarke one in the link has a 6mm nozzle and is a syphon type. I've got one similar at home and it can just about blast a tiny spot before the air runs out. Utterly useless. Turns out a 6mm nozzle running at sensible pressure would require 68cfm! I'd suggest pressure pot or get someone else to do it. http://www.mig-welding.co.uk/sandblasting.htm
The 6mm nozzle isn't the air nozzle, that is much smaller. I'm suprised yours is that bad Malc, mine works OK, but I wouldn't use it for continuous blasting.
