send them back there not realy needed unless your running air tools all day long . ive used them for over 30 years . all is mine get is 3 drops of oil before use and 2 drops when finished then a quick run to get it through to lubricate the bearings ect in case theres moisture left inI recentley purchased two Sealey oilers,i tried one and found that it emptied the container in about 5 minutes.
Has anyone had this problem,is there a way to adjust the ammount that is used,or should i send them back for a refund?
Have run Air Tools For nearly 50 years without in line oilers same as BS few drops when used + Keep the lines DRY either auto vent or drain air Tanks daily or more often if your pressure or volume of air used is highsend them back there not realy needed unless your running air tools all day long . ive used them for over 30 years . all is mine get is 3 drops of oil before use and 2 drops when finished then a quick run to get it through to lubricate the bearings ect in case theres moisture left in
