I am trying to buy the bits I need to setup my airline for spray painting.
I have already bought a selection of compression fittings and copper piping (15mm) from my local diy store. Would these be able to take the pressure generated by the compressor (rated at 8 bar)? If this is likely to be a problem I will take the feed from the compressors regulator and adjust the pressure to what is required.
Secondly, what filters would you recommend I use? The guide on here suggests a filter regulator and oil removal filter. Happy to go with this setup, but which ones are people using and where did you get them from?
Thanks.
Thanks.
