Hi
I have this Wolf Sioux 50L compressor and am planning on using it in my garage for just a bit of DIY on my cars. I also currently have this impact wrench and will probably get some more air tools with time. They would only be used occasionally, so not really any heavy use.
I see from reading the forum, that I would be best to run a 10mm (3/8) ID diameter line for the impact wrench. The best way seems to be running an additional regulator from the bolt on the end of the tank - I think this is 1/2". Or, would I be ok just using my current 10m long, 8mm ID, line that I already have, just connected to the normal regulator on the compressor?
So if going for a new regulator and 10mm (3/8) line, presumably I am wanting the largest diameter of air line and connectors for as long as possible. Therefore, am I correct in thinking that I would connect everything up in the following order:
Reservoir tank --- 1/2" to 1/2" nipple --- Regulator --- nipple --- 10m air hose --- Quick release coupling --- whip hose
So, firstly, am I correct in my assumptions above?
Secondly, the regulators above has a 1/2" outlet, so am I best connecting to the air hose with a 1/2" to 1/4" nipple? Or, am I best chopping off the 1/4" connector on the end of the air hose and using a 1/2" connector - surely having a 1/4" connector between the regulator and hose will immediately introduce a constriction, or is that irrelevant?
Really sorry for the basic questions and the long post!
Thanks
Ben
Thanks
Ben
