I am after some info regarding metal nibblers, I primarily need this to trim up to 2 layers of 0.48mm 5 rib trim deck roof sheeting (they are overlapped at the sheet edges) but would also like the option of cutting heavier steel should the need arise.
If I buy the biggest version which does 4mm, is there any disadvantage or advantage of getting the largest unit instead of the smaller units which do 1.8mm and 3mm. Will the 4mm version cut the overlapped sheets as well or better than the smaller versions? Thanks
