christofloffer
if it says 'dont', then it must be fun!
- shropshire, UK
hi chaps, been a while since i was last on. i have just got myself a 20 gallon blasting pot and i am getting mixed results so i could really do with some pointers. this is a bit long winded but i may as well explain the set up properly.
i am set up in a tin shed with the compressor in the garage separate. i have made up a blasting bay insde using some sheet and an old kitchen extractor hood as a funnel to collect the grit. i also riveted the canvas hood supplied to an old welding mask and made i much more comfortable hood. the compressor is a wolf sioux 50 litre 2.5hp 9.5cfm. i know its on the bottom end of viable but time is not something i am short of so accommodating it is better than replacing it right now. the grit i got is a medium grade crushed glass. i only got 25kg as i didnt know whether i would be better off with a different grade, no better aid for decision making than experience. the work is a mix of steel, iron and aluminium. there is not much ally and i have tried one piece to experiment and its not too bad, leaves it a bit glitters though so i will have to wash it i think. the iron bit came up really nicely and took some primer well.
so, i did the iron bit as my first go and it was a hell of a learning curve but it didnt take too long and i was pretty happy with the result. the ally was more of a faff and took a bit longer as i was holding the nozzle a bit higher to avoid eating into the metal. i made a mistake by only opening the valve at the nozzle halfway to try and make it easier to control. this inevitably ate through the side of the valve so i replaced that. so i after a little trial and error i am happier with my work space.
however i was in there today to carry on and the blaster is not being very effective. at first the amount of grit was fairly thin but it made it really easy to see what i was doing and i liked that. today though the grit is hauling through in a thick stream. this seems to be significantly less effective as when it is flooding through it isnt removing very much at all. i am guessing that its just effectively making a pile of grit rather than firing a smaller quantity that cuts. i tried holding the nozzle higher but that did even less cutting.
there isnt any regulators on the pot, its just four valves to open or close the air in/air out/grit out/nozzle. it also started pulsing but i am assuming that its just the grit getting more prone to clogging as it gets used. i am filtering the grit when putting it back in.
any advice would be really appreciated as its turning into a bit of a bust at the moment.
