I have Sievert torch handle with M14 RH fitting on the end.
I also have propane tank with Wescol Flashback arrestor with 3/8 BSP LH fitting.
I normally use this gas bottle and arrestor for oxy-propane brazing, but occasionally would like to connect the aforementioned Sievert torch, but...
Original Sievert hose, although 3/8" don't seem to fit very well on the arrestor - the shape is different from typical BSP fitting:
on the left Sievert, on the right BSP, both 3/8" LH
What's the best solution? (I don't want to use two separate bottles or two separate arrestors/regulators)
Can I get M14 to 3/8" BSP propane hose? (don't seem to be able to find one quickly)
thank you!
