I am.not sure yet how they get the 24 volts. Whether they use 1.2 AA or 3.7 18650 I am.not certain.I use these in my r/c models, they are 5AH cells but high current.
Samsung 50S - 21700 Battery - 5000mAh - 35A
5000mAh - 35A Continuous Discharge - Flat Top/Button Top/TabsOrder by 3pm (Monday to Friday) for same day dispatch!Brand: SamsungModel: 50SSize: 21700Chemistry: INRNominal Capacity: 5000mAhNominal Voltage: 3.6VDischarge: 35A Max ContinuousPositive: Flat/Button Top/Tabs (please select)Protected...www.nubattery.co.uk
before I used them, I bought one of these
Ampsplus 26650 5300mAh 20A 3.7V Battery
Ampsplus 26650 5300mAh 20A Battery26650 Li-ion 3.7V Battery for Torch, Light, Vape, Mod UK Brand, Rechargeable, Power: 75W, Version: Flat20A Continuous Discharge, Energy: 19.07WhFree case with each pair of batteriesRead more in product details.www.ampsplus.co.uk
but never used it as the charge density higher on the first battey is higher and can handle a higher discharge current, so under high current loads will last longer than the slight higher capacity (second battery)
This is the new one. It's not cheap.I bought from NU Batteries, they're a small business and they test the models they sell in house. Just be sure to go for Korean or Japanese cells from a trusted shop that's verified their origin. The Chinese cells outright falsify their specs. Cell production is complex and not every country has the right capabilities to make them properly.
