gretsch-drummer
Hey all, just purchased a SIP belt 150l 13amp single phase compressor but we've come across a stange hic-up with wiring/plugging it in.
I've got it situated outside undercover were we installed an external socket which is wired to the sheds 16amp fused RCD socket with a ~3meter 1.5mm core lead.
The compressor trips this but when we plugged it into a 25meter 1.5mm core reel extension lead it works perfectly fine.
In basic terms, the compressor trips when using the short 1.5mm core, 3meter lead but works fine when using the thinner core 25meter extension reel.
Is there a minimum length of lead you should use when using a compressor?
(I'll find out the way the wiring is fed into the shed from the house extension tomorrow if it helps.)
