Hi people,
My AS3/50 (twin cylinder, 3hp, belt drive, single phase) developed a fault today - just after I'd put paint in the gun
When you first turn it on it's hunky dory, use the air, then when the motor tries to kick in again it fails and blows the 13amp fuse.
I turned the compressor switch off and it hisses big time ie the valve doesn't shut on the switch (the one fed by the 5mm hose from the cylinder outlet).
I emptied the tank, switched back on and all's well - until you empty the air down to the "kick in" pressure. Motor tries to start but fails & will blow plug fuse.
Yes I know it's meant to be a 16amp socket, but I've been using it like this for years and the switch has never done a continuous hiss. Just the brief one when she's up to pressure.
Any suggestions gratefully accepted
