Hi
I am new to the forum. I have a 3 year old 3hp 50 litre SIP and just after switching it on and it running for a while on saturday there was an almighty hissing coming from the underneath of the control box. As soon as I pull up the switch the air escapes, and stops when I put it back down. The motor sounded like it was stalling and struggling to turn while this was happening.
I stripped the box down last night and it seems that the air is coming out through the small hole at the top end of the black plastic pipe, There appears to be a small brass pin in there but it is totally down in the top of the pipe, ie not stuicking out, but I am assuming that it is supposed to come up out of the top of the black pipe and push into a small metal lever at the bottom of the switch?
I tried clamping the pipe (the compressor started normally & started charging the tank - I ran it to 60 psi then relased the clamp on the plastic pipe, hoping it would clear the sticky pin - but no luck and immediately the air began escaping and the motor began to stall - so I switched off pronto.
I contacted SIP yesterday (I hadn't stripped it then) and he recommended a completely new control unit but wanted the guts of £50.
Can anyone recommend a fix for this or a cheaper source of spares?
Many thanks in advance
Cheers
Alan
Cheers
Alan
