Hi,
First post. I'm not a welder but you lot seem to have a lot of good knowledge about bodywork!
I'm in the middle of restoring my Transporter van. I've got a compressor and a basic Clarke 1.4mm siphon gun. I've used it before and got "good enough" results. Last time I used it I ran it through with thinners to clean it, that was around 3 years ago.
Yesterday I filled it with primer, fired it up and....NOTHING. Reading around I found some tips and tried the following:
1. Tipped gun upside down and put some thinners directly into the threaded inlet where the siphon cup connects to the gun. With the gun connected to the air line it happily fired through the thinners in a decent spray.
2. Filled cup with thinners, connected (checked air breather holes and siphon tube clear, they were) and sprayed - again, nothing!
3. Took gun to pieces, cleaned everything. Still nothing.
What I have noticed is that even with the siphon cup disconnected, there is no "suction" at the inlet port of the gun - if you run the gun I would imagine that your finger should get "sucked" into the gun inlet, no? I'm not getting any suction at all, so, of course, there's no way the gun would suck up paint. Any help?
