Hey guys. I have a fairly cheap arc welder that I got second-hand. It ranges from 20-90 amps and that's more than enough to destroy the metal I'm working with, if I let it (very mild steel, mostly, plus some stronger stuff from bike frames). Some of my welds are pretty good, I think. Others are terrible. I'm using non-descript 2mm rods.
Now, a common problem with my welds is that instead of getting metal along the weld line, I end up with a line of slag with the metal piled up along the edges. I illustrate this below, with two rectangles of metal as examples. In reality I'm working entirely with tubing, roughly 12mm OD and 1-3mm wall thickness.
It's not always quite that bad - usually there will be a fair bit of metal-metal bonding, but with significant lengths of the weld being these "holes" filled only with very porous slag.
It was especially difficult just now - I was trying to weld two tubes together, end-to end, one being very mild steel and the other being from a bike frame. Over several attempts, I threw 18" of rod at this little 40mm weld line, and nothing has stuck
(It's especially tricky because the bike frame metal needs a whole lot more energy to take the weld than the mild steel, which blows out if I so much as look at it.)
I guess this is a "common" problem - can anyone suggest how I can avoid this situation of having mostly just slag joining my work pieces?
Thanks a lot
Thanks a lot
