I'm trying to learn as much as I can because there is so much I still don't know. I did a search on the subject of sand blasters and saw a bit of info. However, I'm not trying to do a whole chassis or anything large, just a few small bits on a car I'm restoring.
Are the small sand blasters that recycle the sand any good or are they really not worth bothering with, I'm guessing that if you don't get a 100% seal then you lose all the sand very quickly?
If I want to remove rust from some panels like sils, where the panels have a 90 degree bent edge that is spot welded to the floor, is this a bad idea because of sand getting stuck in the tight spots?
If using an open sand blaster with no recycle feature, are they dangerous health wise. I mean would I need to buy an air fed mask or can I get away with dust masks?
Is this particular sand blaster the type of thing I should be looking at, or not? I have a 3hp 160ltr compressor that I would use to run it. Is there any words of wisdom when it comes to buying sand blasting equipment?
open blasting is best with a proper airfed blast helmet but u could get away with a simple breathing mask and a grinding visor to stop u been blasted
its uncomfortable but cheap and works. your probably looking about 120 quid for a pot. expendable grit £5.00 for 25kbag can be used twice if sieved
