normspanners
Hi all after putting my two pence worth on another post,it made me think about another project, as my hearing of high freq sounds ie air leaks, is crap has anybody made a smoke pump machine for inlet leaks ? I tried making a steel container which doubled as a hose bung for using smoke matches etc but they dont last 30secs when air is blown over them, it worked but not long enough.
My idea was a cheapo sand blast pot drill the ally pot and fit a couple of old style heater plugs in, by putting nuts either side of the wall of the pot, remove most of the 'dip' tube then put hyd oil mixed with diesel, in it, connect air line (through a adj reg) and where the grit normally comes out connect a tube to connect to your manifold.
Then a push button 'starter' thumb switch (maybe relayed), for the heater plugs, you would have one handed control over each process.
The idea being as you boil the small amount of oil with the heater plugs it would smoke like a b******d the smoke would get drawn out and into the air stream, then forced into the manifold.
Any Ideas?
Any Ideas?
