hi can sum 1 shed sum light on y my welder is useing so much gas it seems to be letting gas out on the slightest touch of the triger way befor the wire feeds starts gomeing out iv had the torch apart and theres 2 rubber o rings inside thge triger i take it thay are to stop the gas escapein into the switch part of the gun would thay be the course of the gfas comeing out befor the wire feed starts would it be adviserble to get new o rings to stop the gas escapein so early ..... hope my wording makes sence and sorr for my spelling many thanks nic
) that one installs a gas solenoid in place of the valve in the torch to control shield gas flow. Since I assume that pressing the trigger starts both the gas and the wire feed at the same time, does this mean there is an appreciable gap between wire feed starting and a full shield developing around the weld?
