hi all, first thread..... well aside from the Hi thread.... not that thats relavent.
I've got a small 130, nice and light weight and does the MOT welding work i do well.
I've recently switched to .6 wire from .8 and 1mm and found it a much nicer machine to use, (the 1mm came with the mach when i bought it second hand), all my tips are 1mm
I've been used to 180 machines when working in garages and switching to the small welder was a bit of a change.
I've found the trigger a bit cheap and slightly offensive to hold.... anyone bothered switching this to a better one?
I've found the wire welds into tip a fair bit esp when upside down, i've never had this as much before, ocasionally sure. its almost imposible to weld upside down now when it never used to be a problem on the bigger machines...
is this just the small machine or the mis sized tips?
Ian
Ian
