Hi everyone, im in need of some assistance. I have a snap on pro mig 2000 which i believe is base on a cebora machine, which is blowing fuses. If i hold the trigger down to feed the wire through then it will quite happily run for as long as is needed, however once i start welding, within two seconds, so maybe two trigger pulls it blows the trip. I bought the welder used and voltage settings 3 and 4 didnt work, i traced this to a burnt out voltage selector switch, which i replaced. All the settings work now, but i wonder if the switch being burnt out is cause or symptom of the overall problem, i dont know if it has maybe back fed and affected something else...rectifier maybe?
Any thoughts greatly appreciated :-)
