richrich123
New Member
- UK
Hiya,
A quick question if anyone could help or has tried this. One of my lines of work is alloy wheel refurbishment. This is via a mobile server (no workshop) so done in a fitted out long wheelbase van. The van has a single booth with extraction fan in the bottom that is used just for sanding and prepping the wheel (the dirty work) and another double booth that is clean and for priming and painting the wheel.
Sanding is all that is needed for most wheels to remove damage from the rim and key ready to prime but now and again I get some that have corrosion or corrosion bubbles just starting. I currently have to sand this away, back to bare alloy. This can take a lot of time but more relevant is that some alloy designs with lots of spokes or intricate design can be very hard if not impossible to get into by power sander and eve by hand can be hard and sometimes impossible.
I don’t have the space in the van to keep a big blasting pot and cant blast sand for example all over a customer’s back garden as it would leave a huge mess.
That was when I saw you can get a 25KG pot of Soda for about £25 and insert a probe with a gun and be able to blast.
Soda gun on ebay
From what I understand, it is less harsh than sand so would leave the alloy with a good finish ready to paint and I was thinking should be ok to blast the wheel in the prep booth in the van as the extractor in the bottom sucks out dust and dirt and deposits it into a bucket underneath. From what I can see, it looks like it could be a solution for the occasional alloy wheel with some corrosion to get it stripped quicker and easier than by hand sanding.
With an alloy wheel, it needs to be finished to at least 240 grit to get a good paint finish so blasting with rough sand/beads etc isn’t much of an option as I guess it would need several rounds of different grits to end up with a finish that is good enough to prime and paint on.
Has anyone with knowledge of blasting think this would be a suitable solution for the occasional alloy with some corrosion? If not, any other suggestions (considering it is a mobile service and I don’t have spare room for lots more kit)
I also know this question has variable such as the size of the wheel, how bad damage is etc but very approximately speaking, can anyone make any guestimate on how much soda would be needed to do the face on a single wheel. Would a 25k bad do a set of 4?
Any help or advice much appreciated. Compressor is 90 litre, 14cfm
Cheers
Rich
Soda gun on ebay
Cheers
Rich
