depends on if your doing it yourself and what gear u have. sodas 25 quid a bag and doesnt go far and can only be used once . it wont remove wheel coatings if its getting painted j blast superfine would be best and give a good key without damageWhat are your views on soda blasting?
I am looking at soda blasting alloy wheels and then painting.
it will take coating of eventualy i cant see it being used more than once as its allready quite fine and would need sieving out after its 1st use. but if u think it will do the job give it a go. its only time and money experementing with itI have all the gear, just need to get a vibrating mechanism on the pot. I have been told by an abrasives supplier that if used in a cabinet you can collect and use 6-7 times. I have seen many video's on youtube and other people have suggested that it would take of the coatings on alloy wheels.
Also if used would primer adhere to it ready for painting?
it will take coating of eventualy i cant see it being used more than once as its allready quite fine and would need sieving out after its 1st use. but if u think it will do the job give it a go. its only time and money experementing with itpersonaly i wouldnt bother with it .use supafine
The reason why i am thinking of using soda blasting is because it is removes the coating and more importantly does not damage the surface of the wheel. i have used supafine and at times it leaves the surface pitted.
I've used re-cycled Supafine and glass grit without pitting ally wheels.
What's the vibrating mechanism you mention?
