Hi guys, new to the forum here! i will be reading quite a bit on here and have been for a while.
I have a Romarc 160 amp welder i got off ebay with a wire feed problem, i solved the wirefeed issue (someone decided to cake the rollers in grease) but have noticed the torch stays live and gas stays on reguardless to the euro torch being plugged in.
So obviously a relay issue somewhere. They are removable and you can take them apart to inspect them. they have a clear cover.
it has a seperate relay for the wire motor, that works on the torch trigger fine.
there is another relay that activates when the power is turned on because i can see it move. i removed it and inspected the contacts. they were Ok.
i think the issue lies with the big power relay that goes to the Solenoid and the main tranformer unit. there is a clip on the side of it that has broken off so the switch is holding on one side. When i turn the welder on by the switch, this big relay instantly clicks on.
Here is a picture of the part i am talking about. The centre of this relay pops in when the powerswitch is turned on.
Hopefully someone can throw some advice my way, i am not too bad witch electrics, i have a clue but not a pro.
