sixtwoeight
Ok, i've made my apology, the more i read the more confused i get, but you all seem easy going enough to be asked simple questions again.
I'm about to start some work on my bmw m535i, it needs several patches of welding done which I should be fine with.
My questions are.
After welding the patch in what primer do you recommend (rattle can will be used) keep reading about epoxy, zinc and etch...does it depend on what paint the paintshop will use? (dont know who will do it yet and wont be for a while)
Does any filler that will be required to the patches go over the bare metal or over the primer? Can filler be left uncovered or does it need primer over top to protect it straight away.
What would you protect the back of a patch with prior to welding in if there is no access to the back of it?
Finally..for now, what product would you use to give a close to factory finish on any patches which are on the underside of the floor? primer then stonechip?
Any makes of primer and filler that you recommend would also be helpful.
Hope you can help,
Cheers
My questions are.
Hope you can help,
Cheers
