gasket999
getting there...
- Manchester, UK
Hi - We have a SiP Nimbus 25050 compressor in the basement (think its 8CFM and 50L)
The motor/pump packed up a few years ago when trying to use a propane cyl as an air receiver (too much work for the compressor).
It was mothballed and a replacement 14CFM compressor was bought.
Now I'd like to run tandem compressors (for extra CFM when shot blasting and also when painting to allow a dedicated comp to be kept outside for an air-fed mask). Luckily I have a 100a supply in the workshop so 2 comps'll work. Both comps filling the propane tank should give a hell of a good setup.
I don't like waste and rather than buying another compressor I would like to see if I can replace the motor pump unit on the SIP - ideally uprating to 14CFM at the same time.
The only reference I can find is a parts diagram here but this is just for the bog-standard 8CFM motor.
I was hoping that there would be some sort of generic pump/motor that would fit but the only one I can find is a piddly little 2hp one in the USA here
Fingers crossed this'll be yet another time when I just haven't a clue and a more knowledgable forum member can point me in the right direction.
Thanks folks.
Thanks folks.
