I assume you mean resistance spot welding, its no different to spot welding mild steel really, as ever, good tip prep and alignment are important, and make sure the mating surfaces are clean. you will need a bit more clamping pressure than for steel, this is tough on the tips so they will need re shaping more often, there are special tips available but usually only for pro machines.
