- UK
We currently spray our stuff using a compressor and a normal (1 litre?) spray gun. These days just spraying primer.
It becomes quite time consuming stopping every 10 mins or so to fill the pot.
Seen spray sets that have a pick-up pipe that drops into a 25l tin of paint, then a couple of hoses to a gun. Quite a bit speedier, plus you don't have the weight of the paint in the pot to deal with.
Do these spray sets still require the paint to be thinned? Seen lads just open a new tin, stick the pick-up in and get going?
Does it take much to clean them? Are they cleaned out with gun wash like a normal spray gun?
Any good makes to look out for?
We try to get the steel sprayed in one coat. Fine line between getting enough paint on and it starting to run. Ideally want to spray it on a little thicker.
