Galwaymick
Hi all
am after some help trying to fix my cebora stag 186. I was welding away quite happily today (repairing the axle on my trailer) turned the machine off for lunch and when I returned about 20min later the machine was dead
now im not to good with electronics but will tell you what I can. I have power to the machine (fan running) I also have 240v power up to the 1st contactor/relay? on the pcb ( grey plastic box with the following markings finder type45.61 16a 250v 24v dc) but I have no readings fro the other side of this in either ac or dc and at any voltage. Removed the power to the fan to try and hear any clicks or other noises from the pcb but it was completely silent. I also tested the continuity of the wires in the torch down to the pcb green plug and this was ok. now I know the machine is quite old and its kept in a damp shed but its never let me down before so im reluctant to bin it (besides im skint) Im also slightly up a certain creek without a paddle without my trailer.
thanks in advace
Mike
,now im not to good with electronics but will tell you what I can. I have power to the machine (fan running) I also have 240v power up to the 1st contactor/relay? on the pcb ( grey plastic box with the following markings finder type45.61 16a 250v 24v dc) but I have no readings fro the other side of this in either ac or dc and at any voltage. Removed the power to the fan to try and hear any clicks or other noises from the pcb but it was completely silent. I also tested the continuity of the wires in the torch down to the pcb green plug and this was ok. now I know the machine is quite old and its kept in a damp shed but its never let me down before so im reluctant to bin it (besides im skint) Im also slightly up a certain creek without a paddle without my trailer.
thanks in advace
Mike
but as it lives in damp conditions it may be a corroded connection somewhere, try operating all the switches a few times to clean the contacts also remove and reconnect any plugs / blade connectors inside the machine (with the power OFF!) to ensure a good contact.
