Was welding a bit of stainless to mild steel galvanized 2" pipe over the weekend, a handy DIY bracket.
I had a 304 rod on my Inverter buzzbox DCEN, 90amps. 4mm thick SS and 4mm walled galvanized pipe.
Action 1 - Just a tack, sticks nicely
Action 2 - Fillet Weld 50mm long - However Weld didn't seem to want to stick to the galvanized 2" pipe. Slag only sticking the 2 together.
Action 3 - Grind off previous attempt and go again with the 304. Same result.
Action 4 - Grind off last attempt and go again this time with a 29/9 rod. Perfect everything sticking together as expected.
Any over see a rod not wanting to stick like that
