That's good you've bought a quality one. AC is really harsh especially on Micky mouse torches and they cook quick 110-140 amps and coping well is very good.Richard, it seems to cope really well. I have pushed 140amps through it earlier without problem and on the cylinder heads I tend to work around 110amps. The torch is not getting hot. I don't do large runs on my jobs. Building up the fins as an example would probably be 20 or 30 seconds welding then some ass scratching then a bit more!!!
I rane a 6" corner weld on 3mm steel earlier to test it and it was fine.
Wow I've never even come close to that sort of tungsten length exiting the cup edge. 5mm is the max I've gone too. I would never of guessed that to work tbh.
Sometimes you just have to stick it out there
I don't doubt it for a second mate. It's just foreign to me to try something like that but like you say how else are you gonna do it.Sometimes on headers I have to get down the bottom of a tight V, how else are you gonna get to it ??? The CK gas lenses allow a lot more stick out, it say so in their blurb
Easy one to make I do it pretty much every time I go from thin ally to thick. I change all my settings but forget to up the post flow and end up with tungsten oxides (purple/blue tip).Yep-do that with me tongue as well as me tungsten,
I did use a 1.6 fairly well stuck out on some ally the other day, used me new CK gas saver, but the tungsten went blue because being a chump novice I did not have long enough post flow I reckon![]()
Does that affect the next weld?Easy one to make I do it pretty much every time I go from thin ally to thick. I change all my settings but forget to up the post flow and end up with tungsten oxides (purple/blue tip).
