Hello all.
First post on here but have spent quite a lot of time in the past reading up on the forum and learnt a lot.
Anyway my problem.
Spent ages renovating a inner wheel arch. Welding, removing rust ect. So used upol seam sealer where required all good there. Unfortunately I have used hammerite stone chip which has reacted in some areas badly with the top coats and left large cracks.
Really annoying because I took several days over spraying this to try and avoid it. Misted the first coat of colour let to dry. Finished off the colour and let to dry. Looked fantastic still - no reaction. Then started on top clear coat and initially for the first few hours it looked great and really felt the time I had spent on it not rushing it was well worth it.
But then I started getting the cracking and the stone chip had basically gone to mush in areas under the paint.
Now what to do???
Some areas look great and have set fully and all it fine.
Other areas are now hardening off (days after the top coat) but have terrible cracking.
First thing I'm not going to use the hammerite stone chip again.
I think using the upol gravi-gard sounds like a much better option for over-coating with paint???
Moving on to how to do this again - would it be possible to wait for the top coats on now to fully dry then roughen and go over with the upol gravi-gard. Let that fully dry and then top coat again???
Would that work or do I need to strip this some how?
Thanks for any help
Anyway my problem.
Now what to do???
Thanks for any help
and not top coated it yet.
