i used to leave it in the pot and if it stood for a while turn it upside down and give it a shake loosen it up as long as your not getting a lot of moisture through the seperator . take a bit out after a while and see if its damp if it is empty and dry it it also depends on what media u are using through itHi
When you're not using the presure pot for a while, can you leave the grit in the pot. Or is I t best to remove it from the pot and put it back in the plastic bucket it came in.
Cheers pink
