jim painter
Well not a problem as such, its more of an annoyance really. I have an old sipair compressor. It has a 200ltr tank and a 3hp motor. The problem is that the compressor will fire up as and when needed without problems but it gets to a certain point and then it slows right down while pumping to the point of almost stopping but after 20-30 seconds it will slowly pick up again. It does it 80% of the time. I did notice with my 20 gallon pot blaster I was getting a lot of water in both water traps (1 on the compressor and one on the blaster) but that could just be because it was running a while. It does get drained regular i.e. before and after use and in between if required. The only other thing I have noticed is there seems to be something bubbling from between the cylinder and head on the pump itself. Is there meant to be a gasket there or is it just pressed together when bolted down.
Thanks for help in advance
