bigdry
Hello all, im in the process of restoring an old Lancia delta rally car. I have previously had the shell acid dipped to remove all traces of paint and rust. Im now doing all the body work which includes adding a lot of strengthening plates, roll cage etc. I intend to have the shell re dipped after this work is completed. The dipping process will re dip in acid to remove any surface rust, hen a complete jet wash to rinse, then has a zinc phosphate layer added (via dipping) and finally it is electrostatically primed like a new production car (also via dipping process). The company I am using is called SPL in Dudley.
My question to you guys is:
What, if any, coating would you put on the back of the reinforcing plates?
i.e. zinc or copper weld through primer maybe? I know from existing plates that are on the car, that i have removed, that the process, despite dipping the complete shell, does not get in-between some layers fully so i cannot rely on acid, zinc and primer to penetrate between the stitch welded plates. However as some liquids some will get in, will this ruin my zinc primer? it’s a quandary i know, and if i leave it bare im sure something will get in there? but can’t be sure.
I think seam welding everything is over kill and there could still be some pin holes in the mig welds.
