the thing to check is the contact rating in the pressure switch. the rating needs to be higher for single phase than it does for 3 phase it will give the amperage on a data plateThats more or less the same, so the procedure I mentioned above applies. Easy peasy !
You just get a motor with the correct mounting flange, shaft size and foot and it's job done.
The pressure switch will have 3 contacts for 3 phase but just 2 would be used for single.
that is the corect way to do it but linking the 3 contacts together and using it as a single pole will last a long time if none of the contacts are pittedsadly that dosent work, tryed it before one conatct allways makes slightly before the others so it ends up getting flashed hard every time.
just buy a contactor rated at more than the motors start current and use the pressure switch to turn the contactor one and off, the addde bonus is when it dose wear out it's not that epensive to change
yes spread over 3 phases. each contact will only be pulling about 5 amp flc whereas a single phase will be pulling about 12 amps and the starting torque will be more eficient than a sigle phase motor edit i thought we were taking about current draw on the pressure switch not motor eficiency another thing wether its single or 3 phase 3hp is 3hp whicheverIt won't be a problem, this model was supplied in single and 3 phase versions.
Also, a 3hp single phase must be the same power as a 3hp 3 phase but may have a little less starting torque.
