Hi
To start with I'm not a welder. More gluing with metal but I'm working on it.
Below is a link to an issue I have......
http://www.doityourself.com/forum/welding-metalworking/456680-help-stick-welding-t-joints.html
I'm using a little 80A inverter with 5mm steel angle iron to practice on. But the other day I had the same issue with better kit.
There appears to be no answer. So here is a guess.....
An arc will always go to one place only at a time. If in the case of a T joint enough heat is generated then both parts will fuse together. Due to low available amps the arc takes on side and only melts a little metal around it. Not enough to bridge the gap.
If this is the case is the answer to get a more powerful welder?
Hold the arc in one place until a good pool forms across the two metals then move very slowly?
If possible vertical weld so the new weld reinforces/ heats the lower weld?
Give up coz I'm talking bo..ocks?
Cheers
Cheers
