I know the fitting the OP is talking about, it has a threaded collar with an open side so the other half of the coupling can be inserted and the collar screwed up to close the flat faces, one of which has a rubber seal. Horrible !! Only solution is to remove them and replace with PCL or similar. If the airline that came with the compressor is nylon tube though, the fitting cannot easily be replaced.
